"DHCP scavenge" - Report for not-used DHCP Hosts
6594     0
After migration to an Infoblox Grid my customer asks if there is an opportunity to clean up the database in the future. The customer uses Host records for everything. Within this he uses the Fixed Address feature for the DHCP allocation of his devices. There are a lot of administrators and a lot of database entries over the years.
Is there an opportunity to mark not used Fixed Addresses/DHCP records when they were not used for over 6 months? Maybe the best way would be a report in Reporting & Analytics. The customer has one reporting appliance. Has anyone a source for the xml code for such a report?
Thank you very much.
Best regards,
Sebastian
Re: "DHCP scavenge" - Report for not-used DHCP Hosts
6595     0
Maybe other people are also interested in this topic. After discussing the problem with Infoblox engineers I could now find out, that it is not possible to to get the list of fixed addresses into Splunk index/lookup table. Otherwise it would be possible to get the requested feature to analyze unused Fixed Addresses by the Reporting & Analytics Appliance.
If you want to push this topic you can add customers with usecase to the RFE-6937
6595     0
I have built this report prototype for my customer, due to infoblox limitation, i need to manually export the fixed address list and upload to the reproting server for the lookup comparison.
6595     0
That sounds good.
Could you describe your work in more detail? Do you export the Fixed Addresses over the API? How do you upload this to the Reporting Server and do the lookup comparison? Do you have a Network Insight appliance or where do you get the time, when the lease was used the last time?
6595     0
Sorry for the late response.
My customer did not purchase Network Insight since their core switch is using Chinese brand vendor such as Huawei.
for the fixed ip list, I just use manual operation to export the result.
CSV Job Manager > CSV Export > IPv4 Fixed Address
2021-02-19-111802
You can also use API to automate this process.
Once I got the latest fixed ip list, I can manually upload the file to Infoblox Reporting server:
Reporting Tab > Settings > Lookups > New Lookup table files. In my example, i renamed the file as fixedIP.csv and uploaded to the Lookup table files
2021-02-19-112354
Then, I created the report using the following logic:
1) ask for the user to select a period of time
2) set the IP ranges (prefix, subnet mask etc) to minimize the search
3) start the search
3a) lookup the fixed ip list ("fixedIP.csv")
3b) filter fixed IP by the user inputed IP ranges (in the step 2)
3c) compare each IP in 3b with DHCP lease history where ACTION="fixed". if there is no match, this means the IP address is not leased during the pre-defined time period (in step 1)
Here is my demo dashboard:
2021-02-19-113527
6595     0
i am not sure why Infoblox community cannot show photo...
you can view the photos here :
https://ibb.co/gdcRsG7
https://ibb.co/44qQVZD
https://ibb.co/nsWgsyz
6595     0
In a great contribution.
Can you share the report to me, so I can use it in my reporter?
