Reporting Data Restore Failed using SCP
3931     0
I am doing reporting data backup and restore test.
So far, using FTP server, I can do reporting data backup and restore with no issue. But if using SCP server, I can do reporting data backup but could not restore it to the reporting server even though same setting is use for backup and restore. The error from syslog is:
splunk_restore: Unable to establish connection using command "/infoblox/reporting/bin/splunk_restore_scp SCP 174.29.69.85 Adziz **** /test/ get_files test" or no file available to restore
From packet capture can see traffic reach to SCP server and there is reply from SCP server.
What could be the problem? Appreciate if anyone could give their thought on this.
Re: Reporting Data Restore Failed using SCP
3932     0
Same issue here, i did not see any reply to this post since March..
PS
3932     0
Same exact issue happened to me running NIOS 8.5.5 - April 27, 2023.
3932     0
I realize these are old posts, but was this ever resolved?  I'm unable to restore reporting backups as well running an 8.5.x release.  I have 180GB of reporting backups and am unable to establish an SCP connection to restore them.  File captures indicate that my connection attempts are making it to the SCP server and I see the connection there but it just drops with the following errors:
splunk_restore[18195]: Unable to connect to host
python: prepare_restore_schedule: Unable to establish connection using command "/infoblox/reporting/bin/splunk_restore_scp SCP x.x.x.x username **** / get_files test" or no file available to restore
*IP and username obfuscated.
3932     0
I wasn't able to resolve this issue.  We decided to start with a new Reporting server this time around because we had that option.  Not ideal.  I wanted to try FTP but there wasn't an FTP server available.
3932     0
Embarrasing but the restore path had to be corrected in order to restore the reporting database properly.  Also SCP restores must be performed from a linux SCP server or the process is different for non-linux servers.
