Adding and modifying names and comment ipv4address and network
4097     0
I have been able to assign a fixed IP and add a network via the API.  I would now like to set the name of the fixed address and the comment of the network.  I have tried to include the name and comment in the POST command during the add and get a bad command error.  I also tried to modify the object with a PUT command and get the same error.  I think my JSON must be wrong, but can't seem to figure out what is wrong.  I appreciate any help!
Examples of what I have tried are below:
Adding fixed address with name:
POST : https://172.25.0.14/wapi/v2.11/fixedaddress
    "ipv4addr" : "192.168.1.2",
    "mac" : "DE:ADSmiley Very HappyE:ADSmiley Very HappyDSmiley Very HappyD",
    "names" : ["Second Fixed"]
Bad Command
Works
Tried modifying with a PUT command:
(I had set the name in the web UI)
GET : https://172.25.0.14/wapi/v2.11/ipv4address?ip_address=192.168.1.2
"_ref" : "ipv4address/Li5pcHY0X2FkZHJlc3MkMTkyLjE2OC4xLjEvMA:192.168.1.2",
"ip_address" : "192.168.1.2",
"is_conflict" : false,
"mac_address" : "de:ad:de:ad:dd:dd",
"names" : ["Innovative Test"],
"network" : "192.168.1.0/29",
"network_view" : "default",
"objects" : [
"fixedaddress/ZG5zLmZpeGVkX2FkZHJlc3MkMTkyLjE2OC4xLjEuMC4u:192.168.1.1/default"
"status" : "USED",
"types" : [
"FA"
"usage" : [
"DHCP"
Using the _ref from the GET command
PUT : https://172.25.0.14/wapi/v2.11/ipv4address/Li5pcHY0X2FkZHJlc3MkMTkyLjE2OC4xLjEvMA:192.168.1.2
    "names" : ["Innovative Test 2"]
Bad Command
I have tried the same and had the same results with a network:
POST : https://172.25.0.14/wapi/v2.11/network
    "network" : "192.168.1.40/30",
    "comment" : "Innovative Small Subnet"
Bad Command
Re: Adding and modifying names and comment ipv4address and network
4098     0
You will want to post updates to the fixedaddress object
The ipaddress object refers to an actual IP Address, and not to the object that is using that IP address.  You can't really change atrtributes of an IP address.
Updating the comment of a Fixed Address will look something like this:
PUT : https://172.25.0.14/wapi/v2.11/fixedaddress/ZG5zLmZpeGVkX2FkZHJlc3MkMTkyLjE2OC4xLjEuMC4u:192.168.1.1/default
4098     0
Thanks for the response!
That got me on the right track.
I had to use the fixedaddress object like you stated, and the name is not set by the names array like it is in the return, but is set using {"name":"New name Value"}
I appreciate your help!
Dave Anderson
