Trying to pull Extensible Attributes using Python for each request
5071     0
I have a python script that needs to pull extensible attributes for any networks that match some criteria. As of now, I can easily identify all of these networks, and pull their references:
payload={'network':CIDR}
r = requests.get('https://url/wapi/v1.0/network',auth=('user','pass'),verify=False,data=payload)
result_json=r.text
JSON_OUT=json.loads(result_json)
for j in JSON_OUT:
	_ref = j['_ref']
So my _ref variable has the refrence to the network I need. My next move, to pull extensible attributes, was to pass in this reference into the GET network and to choose the correct return type:
r = requests.get('https://url/wapi/v1.0/%s&_return_fields=extattrs' % _ref,auth=('user','pass'),verify=False)
print(r.text)
However, this returns the same thing I had before, a Network object. Using curl with the same URLs, I get even weirder behavior. It does return the extensible attributes of the network, however, it immediatley after returns the network object. So my r request object I am assuming is being overwritten by the network object, not the attribute, which is what I want.
Thanks for any help!
Re: Trying to pull Extensible Attributes using Python for each request
5072     0
Hello Andraspalfi,
This approach makes 1 initial call + 1 call per network so it can take a while.
I recommend you to request the MISC return field in the initial call hence reducing to only 1 call
r = requests.get('https://url/wapi/v1.0/network?_return_fields%2B=extattrs',auth=('user','pass'),verify=False,data=payload)
result_json=r.text
for j in JSON_OUT:
	_ref = j['_ref']
 Regards
Nicolas
5072     0
So when I try this I get the following error:
{u'text': u"When sending FORM arguments no URI arguments can be set (FORM arguments: {'network': ['some network ']}  URI arguments: {'_return_fields+': ['extattrs']}), please pass all the arguments as FORM arguments.", u'code': u'Client.Ibap.Proto', u'Error': u"AdmConProtoError: When sending FORM arguments no URI arguments can be set (FORM arguments: {'network': ['some network']}  URI arguments: {'_return_fields+': ['extattrs']}), please pass all the arguments as FORM arguments."}
So I tried to pass all as FORM arguemnts:
payload={'network':CIDR, '_return_fields+':['extattrs']}
r = requests.get('https://url/wapi/v1.0/network',auth=('usr','pwd'),verify=False,data=payload)
But I get the following error now:
{u'text': u"Unknown argument/field: 'extattrs'", u'code': u'Client.Ibap.Proto', u'Error': u"AdmConProtoError: Unknown argument/field: 'extattrs'"}
