API & Integration
Accepted Solution
Using regex in object body request search for IP Address fields
2800     0
    "data": {
        "address~": "10.0.1"
    "method": "GET",
    "object": "lease"
when using a address search in an object body request search above I get the following
Error:"AdmConDataError: Unexpected address syntax"
the documentation for lease states that the address is searchable by regex.
addressStringNYY! < = > ~
What is the correct syntax for this case?
Thanks
Dale
Re: Using regex in object body request search for IP Address fields
2801     0
Which WAPI version are you using? It may be a bug. It's working fine for me on WAPI 2.5 and 2.7. Here is the curl command I used to test it, it gives me a list of all the leases matching that address regex:
curl -k1 -u admin:infoblox -H "Content-Type: application/json" -X POST https://10.60.27.4/wapi/v2.7/request -d '{"data":{"address~":"10.0.0"},"method":"GET","object":"lease"}'
2801     0
Sorry my bad. I had multiple GET calls in one /request but missed a tilde on one if them which quite rightly returned an error.
    push @request, {
        "data" => {
            "address~" => $value
        "method" => "GET",
        "object" => "lease",
        "args"   => {
            "_return_fields+" => "hardware,binding_state"
    push @request, {
        "data" => {
            "ipv4addr" => $value
        "method" => "GET",
        "object" => "record:host",
        "args"   => {
            "_return_fields+" => "aliases"
Thanks for the help
