Creating CSV Files and write data from Cisco devices in NetMRI
1116     0
Hi folks,
I'm trying to use NetMRI to run a pyton script to read information from cisco devices and write them in a CSV file through NetMRI. the script is working from my PC alright but I'm not sure how to do that from NetMRI.
Can you please give me an example on how to open csv files and push data to them from NetMRI.
Thank you
Re: Creating CSV Files and write data from Cisco devices in NetMRI
1117     0
Why kind of data are you looking to get?
You can look at putting the data into Custom Filed per device
https://github.com/infobloxopen/netmri-toolkit/blob/master/Python/NetMRI_GUI_Python/Script%204%20-%2...
Or you can store it into a list or a CSV.
Can you share the script?
https://sifbaksh.com
