Automation Scripts
DSB Bluecoat SG900
Guru
2111     0
The attached DSB and hotfix provides support for the following device:
Vendor: BlueCoat
Model: sg900
Device Type: Proxy
OS Version: 6.5.2.3
This DSB and hotfix should be applied to NetMRI 6.8.3 (because of the hotfix dependency).
