Automation Scripts
DSB NT-ERS-5650-TFD
Guru
2146     0
The attached DSB and hotfixes provide support for the following device:
Vendor: Nortel
Model: ERS-5650-TFD
Device Type: Switch-Router
OS Version: 6.2.6.034
This DSB and hotfixes should be applied to NetMRI 6.8.1 (because of the hotfix dependencies).
