NetMRI Broker - Remote Command
7761     0
Hey All,
I have tried digging through examples and documentation but I'm not sure how to get the info I'm trying to do.  Essentially, I'd like to use the python broker to call the NetMRI API, get a list of devices in the device group and then use NetMRI to run some commands against that list.  The latter portion of this I can do and know how to do pretty easily and I've used the broker before to pull a list (can't say I remember how I got the id ^_~) but as far as pulling items from a device list, I'm a bit stumped...
Thanks!
Edit - I think I figured out the device portion and getting the list of items.  Still piecing together what variable names to use for what...
Re: NetMRI Broker - Remote Command
7762     0
I think what you want to do is first do a search on DeviceGroups bounded by GroupName.  For example, if you had a group called "Cisco" you could send a GET on:
https://<your-netmri>/api/3.2/device_groups/search?GroupName=Cisco
and that would give you back a JSON blob like:
  "total": 1,
  "start": 0,
  "limit": 1000,
  "current": 1,
  "device_groups": [
      "ARPCacheRefreshInd": true,
      "AdvancedGroupInd": true,
      "CCSCollection": 1,
      "CLIPolling": 0,
      "ConfigLocked": false,
      "ConfigPolling": 1,
      "Criteria": "$Vendor = \"Cisco\"",
      "DataSourceID": 0,
      "DeviceGroupChangedCols": null,
      "DeviceGroupDefnID": 25,
      "DeviceGroupEndTime": null,
      "DeviceGroupID": 25,
      "DeviceGroupStartTime": "2017-10-08 01:25:04",
      "DeviceGroupTimestamp": "2018-01-20 13:57:18",
      "FingerPrint": 0,
      "GroupID": 25,
      "GroupName": "Cisco",
      "IncludeEndHostsInd": false,
      "MemberCount": 4,
      "NetBIOSScanningInd": false,
      "ParentDeviceGroupID": 24,
      "PerfEnvPollingInd": true,
      "PolicyScheduleMode": "change",
      "PortScanning": 1,
      "Rank": "1127024707237838848",
      "SAMLicensedInd": false,
      "SNMPAnalysis": 1,
      "SNMPPolling": 1,
      "SPMCollectionInd": true,
      "StandardsCompliance": 0,
      "VendorDefaultCollection": 0,
      "_class": "DeviceGroup"
The key attribute you want from this collection is GroupID:
"GroupID": 25,
which you can then feed into a GroupMembers search, a la:
https://<your-netmri>/api/3.2/device_group_members/search?GroupID=25
and you'll get back:
    "total": 4,
    "start": 0,
    "limit": 1000,
    "current": 4,
    "device_group_members": [
            "DataSourceID": 0,
            "DeviceGroupMemberChangedCols": null,
            "DeviceGroupMemberEndTime": null,
            "DeviceGroupMemberID": 121,
            "DeviceGroupMemberStartTime": "2017-10-08 01:25:05",
            "DeviceGroupMemberTimestamp": "2018-03-18 07:24:42",
            "DeviceID": 3,
            "GroupID": 25,
            "_class": "DeviceGroupMember"
            "DataSourceID": 0,
            "DeviceGroupMemberID": 122,
            "DeviceGroupMemberTimestamp": "2018-03-21 20:14:06",
            "DeviceID": 4,
            "GroupID": 25,
            "DataSourceID": 0,
            "DeviceGroupMemberID": 294,
            "DeviceGroupMemberStartTime": "2017-10-31 20:12:07",
            "DeviceGroupMemberTimestamp": "2018-03-21 18:22:08",
            "DeviceID": 6,
            "GroupID": 25,
            "DataSourceID": 0,
            "DeviceGroupMemberID": 352,
            "DeviceGroupMemberStartTime": "2017-11-05 01:26:07",
            "DeviceGroupMemberTimestamp": "2018-03-21 13:34:08",
            "DeviceID": 74,
            "GroupID": 25,
and then finally for each member of the group you can set a GET on
https://<your-netmri>/api/3.2/devices/search?DeviceID=74
and get back the device's details:
    "total": 1,
    "start": 0,
    "limit": 1000,
    "current": 1,
    "devices": [
            "DataSourceID": 0,
            "DeviceAddlInfo": null,
            "DeviceAssurance": 99,
            "DeviceChangedCols": "DeviceUniqueKey",
            "DeviceDNSName": "router1.somedom.net",
            "DeviceEndTime": null,
            "DeviceFirstOccurrenceTime": "2017-11-05 01:21:04",
            "DeviceID": 74,
            "DeviceIPDotted": "10.255.255.2",
            "DeviceIPNumeric": 184549122,
            "DeviceMAC": "00:19:E8:69:2F:B8",
            "DeviceModel": "2811",
            "DeviceName": "router1",
            "DeviceNetBIOSName": null,
            "DeviceOUI": "Cisco",
            "DeviceStartTime": "2018-03-21 13:32:46",
            "DeviceSysContact": "Joe Bloggs",
            "DeviceSysDescr": "Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(4)M9, RELEASE SOFTWARE (fc3)  Technical Support: http://www.cisco.com/techsupport  Copyright (c) 1986-2014 by Cisco Systems, Inc.  Compiled Fri 12-Sep-14 10:45 by prod_rel_team",
            "DeviceSysLocation": "Server Rack, Bay 1",
            "DeviceSysName": "router1.somedom.net",
            "DeviceTimestamp": "2018-03-21 23:43:33",
            "DeviceType": "Router",
            "DeviceUniqueKey": "0f:1a:85:3b:7b:a0:2f:41:fb:57:bc:26:59:4c:0d:e5",
            "DeviceVendor": "Cisco",
            "DeviceVersion": "15.1(4)M9",
            "InfraDeviceInd": true,
            "MgmtServerDeviceID": 0,
            "NetworkDeviceInd": true,
            "ParentDeviceID": 0,
            "VirtualInd": false,
            "VirtualNetworkID": 1,
            "custom_psirt_severity_threshold": null,
            "custom_psirt_low_threshold": null,
            "custom_eox_status": "End of Support",
            "custom_end_of_sale": "2011-11-01",
            "custom_end_of_support": "2016-10-31 00:00:00",
            "_class": "Device"
Of course, if you're only interested in certain details, you can focus your searches more tightly to optimize.
Hope this helps!
-c
