NetMRI Cisco upgrade script for dual sup devices
- Email to a Friend
03-05-2018 12:48 PM
I am currently in the process of creating a script in NetMRI (CCS) to upgrade a large number of Cisco 4507 devices that have dual supervisors installed. I've gotten pretty far into the script but I'm running into an issue related to the actual reloading of the supervisors. Rather than reloading both SUP's at once, Cisco has documented and recommended that we reload the standby and then wait for that to come back online and then reload the active sup to minimize any outages.
Is there a way in NetMRI to have it wait a specified time period before moving to the next command? Ideally I would like the script to first reload peer, then loop through the following command (show mod | i standby) until the standby is back in an active (sso or standby hot) state. The reload of the peer should take anywhere between 5-10 mins before coming back online. I've attached a copy of the script.
Script-Filter:
$vendor eq "Cisco"
Action:
Upgrade 4507s
Action-Commands:
ARCHIVE ($ipaddress-PRE): show log
SET:$ssomode = "no"
term mon
conf t
redundancy
main-cpu
auto-syn standard
end
show run | i router eigrp
Output-Triggers:
Find eigrp
Trigger:
Find eigrp
Trigger-Variables:
$eigrp string
Trigger-Template:
[[$eigrp]]
Trigger-Filter:
$eigrp like /router eigrp/
Trigger-Commands:
config t
router $eigrp
nsf
end
Action:
Continue upgrading 4507
Action-Timeout:
600
Action-Commands:
redundancy reload peer \r
show mod | i Standby
Output-Triggers:
Determine SSO status
Trigger:
Trigger-Variables:
$sso string
Trigger-Template:
[[$sso]]
Trigger-Filter:
$sso like /Standby Supervisor SSO Standby hot/
Trigger-Commands:
SET:$ssomode = "yes"
Action:
Reload active supervisor
Action-commands:{$ssomode eq "yes"}
copy run start \r
redundancy force-switchover
Thanks in advance!
-Berland
Solved! Go to Solution.
Re: NetMRI Cisco upgrade script for dual sup devices
- Email to a Friend
03-06-2018 10:00 AM
Hi Folks,
Nevermind on this request. I did some research and came across a scripting command in NetMRI referred to as SLEEP.
"The SLEEP directive pauses script execution for a specified number of seconds. SLEEP can be used in Action-Command attributes and Trigger-Command attributes".
Example
- Sleep for one minute sleep: 60
This command allowed my script to wait while the device reloaded its standby SUP and then continued after the sleep timer expired.
Hope someone else finds this helpful!
-Berland
