NetMRI
4210     0
I am unable to send control+C commands to cisco device , it does nothing , can somebody help how to send keyboard short cuts to the cisco devices
Re: NetMRI
4211     0
Are you referring to sending Ctrl-C through a telnet/SSH session window?
Or a script?
Re: NetMRI
4211     0
Are you having issues in sending Ctrl-C from the UI telnet/ssh session ? (as in the following screenshot)
If so, try setting that back to "Control Keys..."
And then send Ctrl-C again
Re: NetMRI
4211     0
I am doing it with python script , yeah it got solved
command = "telnet google.com www /vrf  VRFNaME /source-interface {}\r\x03".format(interface)
