Automation Scripts
Perl Changing enable secret hash
2399     0
I am looking for a solution to the problem of special characters such as '$' in a password hash.
PFA the code.
The script fails if $new_enable_secret_hash consist of strings such as '$asdad$asdjjmm\as5a'.
#!/usr/bin/perl -w
# BEGIN-SCRIPT-BLOCK
# Script-Filter: $Vendor == "Cisco" and $type in ["Router","Switch-Router","Switch"] and $sysdescr like /IOS/
# Script-Timeout: 1500
# Script-Login:
# true
# Script-Variables:
# $save_config string "no"
# $new_line_password_hash password 'none'
# $new_enable_secret_hash password 'none'
# END-SCRIPT-BLOCK
use strict;
use warnings;
use NetMRI_Easy({ api_version => 2.6 });
#Standard Script Variables
our $easy = new NetMRI_Easy;
our $cli_timeout = 10;
our $new_enable_secret_hash;
$easy->send_command("config terminal");
$easy->send_command("enable secret 5 $new_enable_secret_hash");
$easy->send_command("end");
Can you please suggest a solution for this? I want to use hash only and not plain text option of 'enable secret password 0 <abcd>.
Also,
Can we access the lists via Perl? Similar to the getListValue( ) Function on CCS?
