Script Not Reporting Errors
3703     0
I want to give access to my helpdesk to run the IOS Interface State Setting script that comes with Netmri.  I have been testing some use case for this script and when I put in an invalid interface, such as "abcd" or GigabitEthernet1/30000 the script runs and reports a status of ok even though it never changes anything.  I tested this same thing a couple weeks ago and did get an error.  What could cause it to stop reporting errors correctly?  Is this something I need to have Infoblox Support look at?
Re: Script Not Reporting Errors
3704     0
I would say post the script here and I can test and also open a case just in case Smiley Happy
Sif
https://sifbaksh.com
