Using ansible to create DHCP range
10086     0
Hello all,
I have been trying out the new infoblox integrations with Ansilbe 2.5 and can't seem to find anything for setting up a dhcp range inside the networks I setup in infoblox with the playbook below. Am I missing something?
Example playbook follows.
- hosts: ipam-01
  connection: local
  tasks:
    - nios_network:
        network: "{{ item.network }}"
        comment: "{{ item.comment }}"
        extattrs:
           Site: YYY
        options:
         - name: domain-name
           value: xxxxx.com
        state: present
        provider:
          host: ipam01.xxxxx.com
          username: username
          password: somepass
      loop:
        - { network: xx.xx.xx.xx/24, comment: 'Site - Main' }
        - { network: xx.xx.xx.xx/24, comment: 'Site - Phones' }
Re: Using ansible to create DHCP range
Community Manager
Community Manager
10087     0
For Ansible 2.5, the NIOS modules includes NIOS_Network which allows you to create networks but this does not include support for DHCP ranges. The reason for this is that a range is not required for Ansible as a network alone is enough to enable it to pull next available IP address for the given subnet. If you create a network and then a Host record pulling an address from that network, it will work. A DHCP range would only be needed to support actual DHCP clients.
Tony
10087     0
what if I want to configure a dhcp range for a vlan? why I just can't add another task for example to vlan provsioning. is it in the road-map?
10087     0
Useful information, thanks!
