max_result for netMRI
5790     0
Hi All,
Is there any way to limit the resulting data sets from netMRI? like the max_result (IPAM) version of netMRI?
I have a wapi which is reaulting only 1000 lines of data (I'm assuning default value is 1000?)
I tried looking into the wapi doc but couldn't find any anwser.
Please advice.
Nidhi
Re: max_result for netMRI
5791     0
Yes, it’s ”limit”, which defaults to 1000. There is a max though, I think maybe 10k. There should be paging data in the request, you can page through the results to get everything (in Perl, this is done automatically if the query is done in list context).
5791     0
Thanks!
Yes it works.
Nidhi
