need help for trigger-template match
5433     0
i'm trying to match that the copy is succesfull in the following output with a trigger template:
L2DCV2-LABTEST# copy scp://172.16.5.15/Backup/tftp/nxos.7.0.3.I4.6.bin bootflash:nxos.7.0.3.I4.6.bin
Enter vrf (If no input, current vrf 'default' is considered): management
Enter username: admin
NetMRI VM-A033-E27B5 ALL UNAUTHORIZED ACCESS TO THIS SYSTEM WILL BE PROSECUTED TO THE MAXIMUM EXTENT ALLOWED BY APPLICABLE LAWS
admin@172.16.5.15's password:
nxos.7.0.3.I4.6.bin 0% 0 0.0KB/s --:-- ETA
nxos.7.0.3.I4.6.bin 1% 8640KB 8.4MB/s 01:17 ETA
nxos.7.0.3.I4.6.bin 2% 16MB 8.4MB/s 01:17 ETA
nxos.7.0.3.I4.6.bin 3% 23MB 8.2MB/s 01:18 ETA
nxos.7.0.3.I4.6.bin 4% 32MB 7.8MB/s 01:21 ETA
nxos.7.0.3.I4.6.bin 5% 39MB 7.8MB/s 01:20 ETA
nxos.7.0.3.I4.6.bin 7% 48MB 7.9MB/s 01:17 ETA
nxos.7.0.3.I4.6.bin 8% 57MB 8.0MB/s 01:15 ETA
nxos.7.0.3.I4.6.bin 9% 66MB 8.1MB/s 01:14 ETA
nxos.7.0.3.I4.6.bin 11% 75MB 8.1MB/s 01:12 ETA
nxos.7.0.3.I4.6.bin 12% 81MB 8.0MB/s 01:13 ETA
nxos.7.0.3.I4.6.bin 13% 91MB 8.1MB/s 01:10 ETA
nxos.7.0.3.I4.6.bin 14% 97MB 8.0MB/s 01:11 ETA
nxos.7.0.3.I4.6.bin 15% 106MB 8.0MB/s 01:09 ETA
nxos.7.0.3.I4.6.bin 17% 114MB 8.0MB/s 01:08 ETA
nxos.7.0.3.I4.6.bin 18% 123MB 8.1MB/s 01:07 ETA
nxos.7.0.3.I4.6.bin 19% 130MB 8.0MB/s 01:06 ETA
nxos.7.0.3.I4.6.bin 20% 139MB 8.2MB/s 01:04 ETA
nxos.7.0.3.I4.6.bin 22% 148MB 8.2MB/s 01:03 ETA
nxos.7.0.3.I4.6.bin 23% 156MB 8.3MB/s 01:01 ETA
nxos.7.0.3.I4.6.bin 24% 163MB 8.0MB/s 01:02 ETA
nxos.7.0.3.I4.6.bin 24% 166MB 7.6MB/s 01:06 ETA
nxos.7.0.3.I4.6.bin 25% 168MB 7.0MB/s 01:11 ETA
nxos.7.0.3.I4.6.bin 25% 170MB 6.6MB/s 01:15 ETA
nxos.7.0.3.I4.6.bin 25% 173MB 6.2MB/s 01:19 ETA
nxos.7.0.3.I4.6.bin 26% 178MB 6.1MB/s 01:20 ETA
nxos.7.0.3.I4.6.bin 27% 182MB 5.9MB/s 01:22 ETA
nxos.7.0.3.I4.6.bin 28% 191MB 6.2MB/s 01:16 ETA
nxos.7.0.3.I4.6.bin 30% 201MB 6.5MB/s 01:11 ETA
nxos.7.0.3.I4.6.bin 31% 209MB 6.6MB/s 01:08 ETA
nxos.7.0.3.I4.6.bin 32% 215MB 6.7MB/s 01:07 ETA
nxos.7.0.3.I4.6.bin 33% 221MB 6.6MB/s 01:07 ETA
nxos.7.0.3.I4.6.bin 34% 231MB 6.9MB/s 01:03 ETA
nxos.7.0.3.I4.6.bin 35% 238MB 6.9MB/s 01:02 ETA
nxos.7.0.3.I4.6.bin 36% 244MB 6.9MB/s 01:01 ETA
nxos.7.0.3.I4.6.bin 37% 253MB 7.0MB/s 00:58 ETA
nxos.7.0.3.I4.6.bin 39% 263MB 7.3MB/s 00:55 ETA
nxos.7.0.3.I4.6.bin 40% 271MB 7.4MB/s 00:53 ETA
nxos.7.0.3.I4.6.bin 42% 281MB 7.6MB/s 00:50 ETA
nxos.7.0.3.I4.6.bin 43% 289MB 7.7MB/s 00:48 ETA
nxos.7.0.3.I4.6.bin 44% 295MB 7.5MB/s 00:49 ETA
nxos.7.0.3.I4.6.bin 45% 304MB 7.6MB/s 00:47 ETA
nxos.7.0.3.I4.6.bin 46% 313MB 7.8MB/s 00:45 ETA
nxos.7.0.3.I4.6.bin 48% 322MB 7.9MB/s 00:43 ETA
nxos.7.0.3.I4.6.bin 49% 331MB 8.0MB/s 00:41 ETA
nxos.7.0.3.I4.6.bin 51% 341MB 8.2MB/s 00:39 ETA
nxos.7.0.3.I4.6.bin 52% 347MB 8.0MB/s 00:39 ETA
nxos.7.0.3.I4.6.bin 53% 354MB 7.9MB/s 00:39 ETA
nxos.7.0.3.I4.6.bin 54% 362MB 8.0MB/s 00:38 ETA
nxos.7.0.3.I4.6.bin 55% 372MB 8.1MB/s 00:36 ETA
nxos.7.0.3.I4.6.bin 56% 379MB 8.0MB/s 00:35 ETA
nxos.7.0.3.I4.6.bin 58% 389MB 8.2MB/s 00:33 ETA
nxos.7.0.3.I4.6.bin 59% 397MB 8.2MB/s 00:32 ETA
nxos.7.0.3.I4.6.bin 60% 406MB 8.3MB/s 00:31 ETA
nxos.7.0.3.I4.6.bin 62% 414MB 8.3MB/s 00:30 ETA
nxos.7.0.3.I4.6.bin 63% 424MB 8.4MB/s 00:28 ETA
nxos.7.0.3.I4.6.bin 64% 432MB 8.4MB/s 00:27 ETA
nxos.7.0.3.I4.6.bin 66% 440MB 8.4MB/s 00:27 ETA
nxos.7.0.3.I4.6.bin 66% 445MB 8.0MB/s 00:27 ETA
nxos.7.0.3.I4.6.bin 67% 452MB 7.9MB/s 00:27 ETA
nxos.7.0.3.I4.6.bin 69% 461MB 8.0MB/s 00:25 ETA
nxos.7.0.3.I4.6.bin 70% 466MB 7.8MB/s 00:25 ETA
nxos.7.0.3.I4.6.bin 71% 475MB 7.9MB/s 00:24 ETA
nxos.7.0.3.I4.6.bin 71% 479MB 7.5MB/s 00:25 ETA
nxos.7.0.3.I4.6.bin 72% 486MB 7.4MB/s 00:24 ETA
nxos.7.0.3.I4.6.bin 74% 493MB 7.4MB/s 00:23 ETA
nxos.7.0.3.I4.6.bin 75% 501MB 7.5MB/s 00:22 ETA
nxos.7.0.3.I4.6.bin 76% 511MB 7.7MB/s 00:20 ETA
nxos.7.0.3.I4.6.bin 77% 518MB 7.6MB/s 00:19 ETA
nxos.7.0.3.I4.6.bin 78% 526MB 7.6MB/s 00:18 ETA
nxos.7.0.3.I4.6.bin 79% 530MB 7.3MB/s 00:18 ETA
nxos.7.0.3.I4.6.bin 81% 540MB 7.6MB/s 00:16 ETA
nxos.7.0.3.I4.6.bin 82% 550MB 7.8MB/s 00:15 ETA
nxos.7.0.3.I4.6.bin 83% 559MB 7.9MB/s 00:13 ETA
nxos.7.0.3.I4.6.bin 85% 568MB 8.1MB/s 00:12 ETA
nxos.7.0.3.I4.6.bin 86% 577MB 8.2MB/s 00:10 ETA
nxos.7.0.3.I4.6.bin 87% 586MB 8.2MB/s 00:09 ETA
nxos.7.0.3.I4.6.bin 89% 593MB 8.1MB/s 00:08 ETA
nxos.7.0.3.I4.6.bin 90% 602MB 8.2MB/s 00:07 ETA
nxos.7.0.3.I4.6.bin 91% 611MB 8.3MB/s 00:06 ETA
nxos.7.0.3.I4.6.bin 92% 617MB 8.1MB/s 00:06 ETA
nxos.7.0.3.I4.6.bin 94% 629MB 8.4MB/s 00:04 ETA
nxos.7.0.3.I4.6.bin 95% 638MB 8.5MB/s 00:03 ETA
nxos.7.0.3.I4.6.bin 97% 647MB 8.5MB/s 00:02 ETA
nxos.7.0.3.I4.6.bin 98% 656MB 8.6MB/s 00:01 ETA
nxos.7.0.3.I4.6.bin 99% 664MB 8.6MB/s 00:00 ETA
nxos.7.0.3.I4.6.bin 100% 666MB 7.8MB/s 01:26
Copy complete, now saving to disk (please wait)...
My trigger-template is the following:
Trigger-Template:
When I test it in the Regular Expression Test wizard, it does match the output, but when I run the script, it does not mat...
Who can help?
Benjamin
Re: need help for trigger-template match
5434     0
I just ran a test and it worked on Version 7.2.1 in the RegEx test
Also, I recommend using an MD5 Hash command to check the integrity that is easier and cleaner as well Smiley Happy
 05:07:01 	 Trigger-Template
 05:07:01 	  	 Template matches
 05:07:01
 05:07:01 	 Trigger-Commands
 05:07:01 	  	 SET: $donothing = "true"
https://sifbaksh.com
5434     0
Just to add to what Sif recommended... NX-OS does not support the "verify /md5" command from IOS.  Instead you have to use "show file bootflash:nxos.7.0.3.I4.6.bin md5sum".  Have the script compare that to the published value on CCO.
