python API NetMRI send variable to run Script broker->script->run
10664     0
i used your python example to run a script.
Now i would send variable informations to the script.
But in the job there ist no values.
devices = broker.find(
    op_DeviceName='like',
    val_c_DeviceName=args.device_id,
    select=['DeviceID']
script_broker = client.get_broker('Script')
# submit the job to the NetMRI
job_id = script_broker.run(
        name=script_name,
        device_ids=[x.DeviceID for x in devices],
        script_variables = "$commands_to_be_executed 'show version'",
"script_variables = "$commands_to_be_executed 'show version'" will not be used.
Can you send me a example with one and two variables ?
Re: python API NetMRI send variable to run Script broker->script->run
10665     0
You pass each variable as it’s own parameter. I’m not sure in Python, but in Perl that means that, ’$commands_to_be_executed’ should be key in the hash (dict) that gets passed in, just like ”device_ids” or ”name”.
10665     0
Hello JBelamaric,
thanks for your reply.
But in the API Dokumentation - Python - v3_2_0.ScriptBroker "broker.run - INPUTS" i found:
script_variables Required:False type: String
Optional variables to be passed to the script. Any variable name starting with $ will be passed through as input to the script.
But it will not work.
10665     0
Yes, the docs are not entirely clear there. I thought there was more description about this in there, that you shouldn’t create an actual input called ’script_variables’ - instead you should create inputs named for each of your variables, including the $ in front.
10665     0
Hello JBelamari,
what ist wrong on this line  ?
Complete Lines:
        name=script_name,
The JOB starts but with no commdand 'show version'.
What is wrong ?
10665     0
You shouldn’t have a parameter named script_variables at all. Instead, you should have ’$commands_to_execute’ as *it’s own parameter*. Every parameter passed in that starts with ’$’ will be treated as a command input. The documentation here is not clear, we need to fix that.
10665     0
Not sure if it works exactly like this in Python, but it would be something like:
name=script_name,
”$commands_to_be_executed”="show version",
Though it might need to be a bit different syntax in Python.
10665     0
Your Example did not work:
name=script_name,
"$commands_to_be_executed"="show version",
I get this error message: "SyntaxError: keyword can't be an expression"
10665     0
Here is python script function from Sif that I adapted/adopted, it uses the api instead of the broker.  The device id is hard coded:
def run_adhoc():
        data = client.api_request(
                'scripts/run', params={
                        'name': "Ad Hoc Command Batch",
                        '$commands_to_be_executed': "sh version",
                        'device_ids': "290",
                        'credential_mode':'requestor',
-Lon
10665     0
I have asked the team to look into this in Python and how it can be done more cleanly/documented better.
The last example in the Perl Tutorial in the documentation shows how to do it in Perl:
# run the script against the devices specified on the
# command line.
my($job_id) = $client->broker->script->run({
name => 'API Example 9 - Synchronous Perl Job',
device_ids => \@ARGV,
'$command' => 'show version',
})->{JobID};
# fetch the Job object
my $job = $client->broker->job->show({ JobID => $job_id })->{job};
John
10665     0
I have the solution Smiley Happy
This tip helps me: Python - External Script to Run the "Ad Hoc Command Batch" on NetMRI
defaults = {
    "host": hostname,
    "username": username,
    "password": password,
client = InfobloxNetMRI(
    defaults.get("host"),
    defaults.get("username"),
    defaults.get("password"),
#    api_version=2.8,
# get broker for specific API Object
broker = client.get_broker('Device')
# get devices
job_commmands = "show version"
    select=['DeviceID']
save_new = {
    "name" : script_name,
    "device_ids" : [x.DeviceID for x in devices],
    "$commands_to_be_executed" : job_commmands,
    "job_name" : "Show config",
job_id = script_broker.run(**save_new)
Thies Person inspired me (thanks to): JBelamaric, SBaksh, LThompson
