python scripts connecting to port 8787 on the grid master
3354     0
We have a customer trying to connect to the infoblox grid master at port 8787. Where can I get some pre canned python scripts that will do the following.
1. create the instances and VPC’s via the api.proxy to do some tests.
2. example of what the infoblox grid master certificate should look like in terms of SubjectAltName fields.
