B1-105 device mount brackets
2187     0
Afternoon, are there any rack mounting kits/brackets for the B1-105 please? I know they are small, but keen on finding out, thank you.
Re: B1-105 device mount brackets
2188     0
Hi Kendra123,
Regarding rack mounting kits/brackets for the B1-105, we specify a movable tray that's installed in the 4-post rack. A B1-105 can be placed on each tray. I am trying to get additional information for you, but it's not a frequently submitted request. Do you think a movable tray would work for you? If so, how many would you need?
2188     0
Hi Kendra123,
One additional note: each movable tray can hold four (4) units of B1-105 B1DDI. It's after hours now, but I will follow up as soon I receive additional information. Thank you again for your interest in BloxOne DDI!
2188     0
Hi Kendra123,
Here's a resource for the movable tray: https://www.amazon.com/Penn-Elcom-R1291K-2L-Theatres/dp/B005GPYDVQ/ref=sr_1_14?dchild=1&keywords=rac...
Please let me know if you have further questions or feedback. Thank you.
2188     0
Hi bob, that is excellent thank you for your response(s), extremely helpful!!
