Client Fail to update DDNS using gss-tsig
4708     0
Hi Teams,
Im doing some lab about ddns. The scenario will be client (already join domain to corp.abc.net) update their IP to Infoblox that running dns.
here what i've done:
1. create user on domain controller (ib, password P@ssw0rd)
2. create keytab file on domain controller (ktpass -princ DNS/ib.abc.net@CORP.ABC.NET -mapuser ib@corp.abc.net -pass P@ssw0rd -out c:\ns1.keytab -ptype krb5_nt_principal -crypto AES256-SHA1)
3. Already import the keytab to Infoblox.
4. Execute command ipconfig /registerdns from the pc client
after the above activity, i check the logs on infoblox:
2020-04-26 21:56:01 ICT daemon ERROR named[13999] gss_accept_sec_context: continuation call to routine required
2020-04-26 21:56:01 ICT daemon INFO named[13999] GSS-TSIG verify stats: 0 ok, 0 failed (0 integrity, 0 time)
2020-04-26 21:56:01 ICT daemon INFO named[13999] GSS-TSIG accept stats: 0 ok, 1 failed (0 NTLM, 1 principal, 0 key, 0 integrity, 0 time)
2020-04-26 21:56:01 ICT daemon ERROR named[13999] 192.168.137.20#59616: GSS-TSIG authentication failed for (DNS/ib.corp.abc.net@CORP.ABC.NET, kvno 4, arcfour-hmac-md5): unknown principal
2020-04-26 21:56:01 ICT daemon ERROR named[13999] client @0x7fd5840f9000 192.168.137.20#57468: update 'corp.abc.net/IN' denied
any step that i miss?
thanks
Re: Client Fail to update DDNS using gss-tsig
4709     0
This issue happen because the DC adminitrator create a wrong keytab file. it's not mapped to correct user that already created.
Thanks
4709     0
I followed the same steps and mapped right username. But in infoblox syslogs i am getting below error -
10.239.40.254#54721: GSS-TSIG authentication failed for (DNS/ip-ib-00011-z5e.infoblox.com@domainname.net, kvno 6, arcfour-hmac-md5): unknown principal
Any suggestion for this ?
4709     0
I see that your Clients are asking with the wrong encryption scheme "arcfour-hmac-md5"
I think the Infoblox Support Documents lack a important information.
Fix
Please check if the Service AD Account you map to the ktpass tool has the Checkbox "This account supports Kerberos AES 256 bit encryption".
If not, check it, regenerate the keytab file, upload it to the appliance and reboot the dns client machine
Now they should query the AD Controller and choose the higher AES256 encryption for gss-tsig updates
