DHCP treshhold notification body
3379     0
I have configured IPv4 DHCP Threshold Email notifications for Networks. And receive the following messages when value triggered:
Subject : DHCP high threshold crossed
Message: DHCP high threshold crossed:
  Range: {IP Range}///
  High Trigger Mark: 90%
  High Reset Mark: 80%
  Current Usage: 90%
  Active Leases: 10
  Available Leases: 1
  Total Addresses: 11
Reporting: DHCP
Node: {Ip addr}
Time: Fri Nov 24 12:26:52 2017
Do you know if it is possible to change Subject and Body of this message? I wold like to add some Extensible attrubutes in order to have more information about subnets.
Thank you.
Re: DHCP treshhold notification body
Community Manager
Community Manager
3380     0
Unfortunately this is not possible with any versions of NIOS. You may contact your Accounts team to prioritize the feature request "RFE-4736 - Customer wants to see EAs associated with Network/Ranges in SMTP/email alerts, related to high thresholds".
3380     0
Thank you for usefull comment.I will take it into account.
