Device management interface
3556     0
Hi infoblox Experts Community,
I have some infoblox appliances, and they have four interfaces each one: LAN1, MGMT, LAN2, and HA Interfaces.
We want to use the mgmt interface for management traffic and the LAN1 for operational traffic.
As I know we have to configure a MGMT gateway, and also configure a default gateway for traffic that goes through the LAN1 interface, so I beleive that I have to configure a static route for the management traffic because we could have some routing issues.
Is that correct?
Re: Device management interface
3557     0
Yes, you will need to do routes for anything that needs to go over the MGMT interface, outside of any directly-connected subnets, or else the default route for LAN1 will be used.  To do so, go to Grid->Grid Manager->Members, make sure Advanced Mode is toggled (upper left of the dialog box), then edit the member in question, and add the routes under Network->Advanced.
