DNS DHCP IPAM
Accepted Solution
How to delete IPv4 address for LAN1 (PT2200) under dual mode?
4283     0
LAN1 and LAN2 are configured as port redundancy.
We configure IPv4 for all ports (LAN1/LAN2/MGMT) at first.
But we want to change address of LAN1/LAN2 into IPv6 when keep MGMT IPv4.
When setting Type of Network Connectivity into dual mode, cannot delete IPv4 address of LAN1.
Is there any way to fix it?
Re: How to delete IPv4 address for LAN1 (PT2200) under dual mode?
4284     0
Hello, kqiong
Could you please inform what version of NIOS are you using?
Paulo
4284     0
the version of NIOS is 7.3.8
4284     0
If you set the "Type of network connectivity" in dual mode, both IPv4 and IPv6 must have IP addresses.
According to your requirement, you only need to configure the "Type of network connectivity" as IPv6.
and then in the "Additional Ports and Addresses", you can add MGMT (IPv4) interface.
Attached the screenshot for your reference:
4284     0
thanks, man
