IPAM Perms with or without MS management
3243     0
Hello:
Do IPAM Perms matter whether the Network space is on a MS Server (being managed by a Grid member with MS MGMT) or wiithout it?
I think it applies to both but wanted to check.
Thanks
Re: IPAM Perms with or without MS management
3244     0
Hello Hammer,
You are correct. Permissions apply to both of them.
Keep in mind that when configuring a MS Server in Microsoft Management, you can select the permission level defined on Grid for that Server (image attached). If you set a Microsoft Server in Read-Only mode, even if you have admin rights to edit IPAM (DNS and DHCP objects), you won't able to change a thing.
However, if you set up Microsoft Server in Read-Write mode and if you have proper DNS and DHCP permissions, changes in IPAM to MS Networks will apply accordingly.
Hope this helps!
Paulo Costa
