IPAM and Network Insight
3532     0
Hi...
We are having a IPAM Grid of 3 members with Network Insight (3 Probes Modules)...in network insight we have enabled IP Discovery and DHCP Server Sync(Microsoft Server)
I have a question on the interoperability between IPAM and Network Insight.
Will the IPAM DB will get updated with the Subnet Informations synced via Network Insight ?
Thanks & Regards
KK
Re: IPAM and Network Insight
3533     0
Network Insight will add all the subnets (directly attached routes) it finds on various routers as ”unmanaged”. They will show up as yellow in the IPAM tab. You then can select specific ones you want to manage (or all of them) and ”Convert” them to managed subnets.
John
