Infoblox DHCP with Cisco Access points issue
11848     0
Hi
i am trying to deploy some Cisco access points and need to issue option 43 and 60 in DHCP so that the APs get directed to the correct wireless controller. The AP isn't registering on the controller so I'm guessing that these options are not being passed correctly.
Any one test this configuration before ?
Appreciate your help
BR
Mohamed
Re: Infoblox DHCP with Cisco Access points issue
11849     0
11849     0
Hi
Actually we find the soultion for this issue, we were trying to add the MAC address of the Cisco WLC in option 43 using the following format aaaa.bbbb.cccc but when changing this format to aa.aa.bb.bb.cc.cc everything is working fine and the cisco AP can register with the cisco controller. we didnot need to add the configuation in the above link.
Thanks
11849     0
Dear mmaklad ,
How the AP will learn controllers MAC address if they are connected in different switches.
Thanks
