DNS DHCP IPAM
Accepted Solution
Is there a guide that shows how to implement two VNIOS appliances in HA?
Guru
1402     0
Basically, I want to install the HA pair in the same Data Centre but on  separate hypervisor hosts. I know for physical Trinzic DDI appliances you need to have spanning tree off on the switch ports connecting to the appliances. Are there any requirements like this for Vnios.
Also, do you need to configure one ESXi port group for the LAN1 interface and another for the HA interfae or do you need two NIC cards on the hypervisor?
Kindly
Wasfi
Re: Is there a guide that shows how to implement two VNIOS appliances in HA?
1403     0
Basically it;s the same as for physical appliances. You get 4 interfaces (MGMT, LAN1, HA and LAN2)
LAN1 and HA need to be in the same subnet like the physical appiances. Depending on you ESX version you need to disable security settings on the vSwitch else the HA port will not come up, that's all, no things like spanning tree, speed duplex on vNios. There are installation guides available on the support download site.
