Mitigating network load balancing issues
1566     0
If you are facing/trying to solve any of the following use cases, you will benefit from joining our upcoming community webinar.
  • Internal & external DNS-based applications
  • Disaster recovery
  • Amazon Web Service (AWS) / Microsoft Azure / On-premise apex domain routing
  • Domain/zone consolidation
  • Internal and hosted applications (e.g., Microsoft Skype for Business)
  • Global data center management
  • SaaS
Register for the community webinar - https://infoblox.zoom.us/webinar/register/4315257216556/WN_pSpR2lFdRSKmjliVsMvIGw
Date and Time - May 8 at 10 AM PDT
Speakers - Nathan Snook and Scott Friedman (Infoblox SE team)
Nathan and Scott will discuss how you can use Infoblox DNS Traffic Control (DTC) to solve the above use cases easily and affordably. There are situations where the current load balancing solution doesn't help. In other situations, using the current solution is prohibitively expensive.
Check out our new Tech docs website for latest documentation on Infoblox products.
Re: Mitigating network load balancing issues
1567     0
In case you missed the webinar, here is the archive URL.
