Network Discovery Automatic Conversion Fixed Address Help
1244     0
I am trying to setup an automatic conversion rule to convert discovered IPs to fixed addresses.  My conversion templates is "${discovered_name}".  When discovery runs, it does convert the addresses to an IP4 Fixed address, but the name remians blank.  It does have a name under discovered name.
If I manually convert a discovered address to an IP4 fixed address, it converts it and saves the discovered name as the name.
If I use the same conversion rule, but use it to convert to a Host record, the host record has the name to set to the discovered name.
What do I need to do to convert a discovered address to an IP4 fixed address, with the disocvered name as the name? We are using a Network Insight server for discovery.
