Problems importing hosts via csv
2111     0
Hi team,
I am experiencing issues when I try to import host using a csv file. I use the next csv file:
header-fixedaddress;ip_address*;_new_ip_address;always_update_dns;boot_file;boot_server;broadcast_address;circuit_id;cli_credentials;comment;ddns_domainname;ddns_hostname;deny_bootp;dhcp_client_identifier;disabled;domain_name;domain_name_servers;enable_ddns;enable_discovery;enable_immediate_discovery;enable_pxe_lease_time;ignore_client_requested_options;lease_time;mac_address;match_option;ms_server;_new_ms_server;name;network_view;next_server;option_logic_filters;override_cli_credentials;override_credential;prepend_zero;pxe_lease_time;remote_id;routers;snmpv1v2_credential;snmpv3_credential;use_snmpv3_credential;EA-VLAN;EAInherited-VLAN
fixedaddress;10.20.32.90;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;SCADA;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.11;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;EDAR Güeñes PC del Sinoptico (Proyector);default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.20;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;Automata Bombeo de Sodupe (SGUE 310 B1);default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.21;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;OSM Bombeo de Sodupe (SGUE 310 B1) ;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.30;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;PLC Bombeo Estacion Sodupe;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.31;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;OSM Bombeo Estacion Sodupe;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.200;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;OSM de Control;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.201;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;OSM de Fangos;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.58;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;Impresora EPSON;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.13;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;Ordenador ofimática LKI;default;;;False;False;False;;;;;;False;300;OVERRIDE
fixedaddress;10.20.32.100;;False;;;;;;;;;;;False;;;;True;False;;;;00:00:00:00:00:00;RESERVED;;;PC ingenierias;default;;;False;False;False;;;;;;False;300;OVERRIDE
It seems okey and I have used the same header that a export I did, but I am getting the error mesaage, "Please input a valid csv file." . I have seen other discussions in which the infoblox doesn't let upload the recently exported csv but in this case, it lets. I have to be comitting an error but I am not able to find it.
Thanks in advance!
Re: Problems importing hosts via csv
2112     0
Have you tried to use commas instead of semicolon's?
2112     0
Do you export the csv with option: Export data in Infoblox CSV Import Format?
Thanks
2112     0
I have the same problem. I've just done export data in infoblox csv import format file - but next import show errors. Even I try import file with host which have been exported 1 minute ago...
