Radius authentication class attribute for group fails
3117     0
Hi Bloxers,
I configured radius auth and keep getting group mapping errors.
to=AdminConnector ip=172.22.200.249 info=Admin has no enabled groups apparently_via=GUI:
The radius server I have is a small utility called luteus radius used only for labs.
It supports the class attribute and I see the radius responding with class attr which I think is the group.
I do see some issues with attr 32 and 80, what response is infoblox expecting for these?
Tue Mar 12 12:05:42 2019;<188>;0;Received unknown attribute 32;
Tue Mar 12 12:05:42 2019;<188>;1;Received unknown attribute 80;
Send ok Respond to 010.001.062.021:48101
Tue Mar 12 12:05:46 2019;<188>;2;Received unknown attribute 32;
Tue Mar 12 12:05:46 2019;<188>;3;Received unknown attribute 80;
Send ok Respond to 010.001.062.021:58055
Thanks.
