Reboot node or nodes of a Grid using WAPI
1786     0
I am looking for an API to reboot a grid member nodes(s) using Rest API (/WAPI)?
This is possible from the user interface from Control options of Grid member but I couldnt find any documentation in API.
Appreciate the quick help.
Thank you.
Re: Reboot node or nodes of a Grid using WAPI
1787     0
Were you able to figure this out?
I realize this was asked 2+ years ago.  Hoping you were able to or bumping so maybe someone else has an answer.
Either way, thank you!
1787     0
I just looked at the WAPI 2.12 guide, In the admingroup:machinecontroltoplevelcommands :
Toplevel commands, you can set boolean values for reboot, reset, restart, and shutdown. This allows the cli user to run the commands.  No command from API to run a reboot command.
