Required Extensible attribute
3595     0
Do anyone know if it is possible to apply Extensible attribute with Required option only to specific subnet? Now when I create EA with Required option, it affects all network objects in IPAM.
Thank you.
Re: Required Extensible attribute
3596     0
unfortunately no, when you make an Extensible Attribute required, it is required to enter a value for all objects you've restricted the EA to apply to.
What you could do is to fill in a "NA" value. This is what I do for List type for instance so that I can still save the object.
Ben
3596     0
Hello Benzaam,
Thank you for your usefull comment.
