DNS DHCP IPAM
Why is that VRRP needs to flow to both HA and LAN1 ports of the passive node?
Guru
1300     0
Why is that VRRP needs to flow from the HA port of the active node to both HA and LAN1 ports of the passive node? why not only the HA port or only the LAN1 port?
Kindly
Wasfi
Re: Why is that VRRP needs to flow to both HA and LAN1 ports of the passive node?
Moderator syam
1301     0
Hello WBounni,
The HA interface of active joins the multicast group using VRRP MAC address. This is to avoid potential MAC flapping issues.
Syam.
