Device expiration for Failed to reach devices
2503     0
Greetings all,
The "Device Expiration in Days" is set to 7 (default), however, I see devices that have been decommissioned more than 2 weeks ago. The discovery status shows "Failed to reach" but the SNMP authentication and collection are showing green check, successful as of current time.
These devices were created via static ip. Should remove these devices manually once they decommissioned rather than waiting for automatic removal?
Thoughts and comments are greatly appreciated.
Yes. I believe if the device
2504     0
Yes. I believe if the device is present as a static IP, it will not be removed.
Static IP or seed router, for
2504     0
Static IP or seed router, for that matter.
That was it, thank you.
2504     0
