How to upgrade Cisco using Archive Command
4900     2
Script:
IOS Upgrade Archive CMD
Script-Description:
IOS Upgrade Script for Cisco devices supporting the archive method to upgrade devices.
Script-Filter:
$Vendor eq "Cisco"
Script-Variables:
$tftp_server string "Enter the tftp Server IP"
$image_filename string "Enter the Complete Image Filename"
$no_version_check boolean
$reload_now boolean
$reload_in string "enter the reload in text here"
Action:
Archive Download
Action-Description:
This executes the Archive Download command which downloads and installs an IOS image.
Action-Timeout:
5400
Action-Commands: {$no_version_check eq "off"}
archive download-sw /overwrite tftp\x3A//$tftp_server/$image_filename
Action-Commands: {$no_version_check eq "on"}
archive download-sw /overwrite /no-ver tftp\x3A//$tftp_server/$image_filename
Action:
Reload Device
Action-Description:
Reload the device only if one of the reload options have been selected.
Action-Commands:{$reload_now eq "on"}
reload in 1\r
Action-Commands:{$reload_in not like /enter the reload in text here/}
$reload_in\r
Some other examples Smiley Happy
https://community.infoblox.com/t5/Network-Change-Configuration/Upgrade-IOS-Image-on-Cisco-2960/m-p/2...
https://sifbaksh.com
Re: How to upgrade Cisco using Archive Command
4901     2
Thanks for sharing this.
-Srinivas
Check out our new Tech docs website for latest documentation on Infoblox products.
