Is it possible to use a script variable in a script filter?
1733     0
I am trying to run a script on a subset of devices in a group- in this case based on the name.  If i hard set the name in the filter it works fine, but i would like to make it more extensible and allow the user to enter the filter parameter without editing the file.
Is the following possible? (this code doesn't work, so i'm missing something if it is possible)
Script-Variables:
    $Commands_to_be_Executed    text        "Enter commands here, one per line"
    $devicename string "device name"
Script-Filter:
    $Vendor eq "Cisco"   and
    $sysDescr like /IOS/ and
    $Name like /^$devicename\.\d{4}/
Action-Filter
1734     0
Why don't you try setting it at the action level Smiley Happy
Action-Filter:
https://sifbaksh.com
