Accepted Solution
Is there a guide for using RegEx config searches?
3960     0
Is there a published guide on using the regex functionality in Config Searches?  Help only says you can use regex, but doesn't detail what is actually supported.
I need to search for a line within a block of code and none regex variations i've tried bring anything back. do the 'm' and 's' flags work for multi-line searching?
Re: Is there a guide for using RegEx config searches?
3961     0
Here is an example Smiley Wink
I'm not sure it those options are allow
^line vty \d+ \d+\n(?:\s[^\n]+\n)*(?:\sexec-timeout \d+ \d+\n)/m<
Looking at VTY settings to see if exec-timeout is in the config
Sif
