Accepted Solution
Is there a way to list and manage Roles + Device Groups for users??
9512     0
I see that I can get alist of what roles a user has, but so far I have not found a way to list the Device Group(s) associated with the role. Is that even possible? And what aboput adding, deleting, and updating Role+Device Group associations via the API? Would prefer Perl over WAPI. Using NetMRI 6.9.4.
Re: Is there a way to list and manage Roles + Device Groups for users??
9513     0
Roles are not directly related to device groups. Rather, a given user has specific roles for specific device groups. So, it is the user that connects roles and device groups.
John
9513     0
Sorry if I was not clear, this is about automating user audits and managing users. The web interface does appear to provide any way to see the Role + Device Group associations beyond drilling down into each user, which is unacceptable for security and compliance auditing purposes (NetMRI is a layer 2 device for PCI DSS concerns here at EHI), and a real pain to e.g. add access to a new Device Group for over 100 users. Is is possible to do these with the API, and if so, are there any examples showing how to do it. The closest I have seen is a Perl script in the forums here that lists the roles, but so far I have not seen anything about the device groups associated with the roles.
9513     0
Is the auth_roles call on the auth_users controller what you are looking for?
https://netmri/api/3/auth_users/docs#auth_roles
John
9513     0
That looks promising. Right above that is add_auth_role, which takes a lsit of Deivce Group IDs. Is there a way to get a lsit of the ID to name mapping for the Device Groups?
9513     0
That would come from the Device Groups API.
https://netmri/api/3/device_groups/docs
By the way, I just noticed "Would prefer Perl over WAPI”. In NetMRI, the Perl API is just a wrapper on top of the REST API (WAPI). So, anything you see in the online docs should have a Perl equivalent - we actually generate the Perl modules as part of the build process, based upon what is in that documentation. You should also see it using ”perldoc”.
John
9513     0
I'm aware of that. I was hoping some additional fucntionality may have been added to the Perl API (like NetMRI_Easy.pm simplifies things) to make this easier. We can't be the only ones doing this and at least the user audit piece should be included out of the box.
9513     0
Problem! I am doing an "@auth_users = $netmri->broker->auth_user->index( );" to get a list of all users. However, users with multiple roles do not appear to be included in that list!
I also tried a $netmri->broker->auth_user->search( user_name => qw[user_with_multiple roles] ) and get an empty array back.
I verfied the user still exists and is enabled/active via the GUI.
Am I missing something?
NetMRI 6.9.4 (in an OC environment).
9513     0
Hard to tell. Seems like it should work as you expect. Might help if you can attach the script.
9513     0
Doh!! I was figuring out what I could paste in in when I realized I was hitting our lab instead of production! I've been doing all the recent development work in our production. I started this script several months ago but had to stop working on it for this project. So back then I was working in the lab for most dev, but now prod, and I never updated the script. It's one of those things that "looks right" so takes forever to catch.
9513     0
Smiley Happy
9513     0
Has anyone run into a Device Group GroupID that does not exist in the list of device groups (not counting 0)? We have a handful of users with a device group that apparently no longer exists. If I drill down into one of these users in the GUI it's not listed there. My guess is these users have a reference to a device group that no longer exists. Just curious if anyone else has seen this.
9513     0
Thanks for all the help! WHen I get a chance I will try and clean the script up and post at least some of the simple auditing reports.
I was also able to add a new device group to a role for users that had said role, and fix a user that had no roles and did not appear in the GUI.
Anyway, appreciate the help.I have my head wrapped around the API much better than before. Good stuff!!
