Need to disable and re-enable and interface
1838     0
I am running into an issue with our IB-820 appliances, running as an HA pair, is reporting that the 'HA member is offline'. However, I can ping it and SSH to the applicance. I opened a support case and am told I need to disable and re-enable the LAN and HA interfaces. Going through the manual but I don't see any instructions on how to do that. Looking for some assistance.
Re: Need to disable and re-enable and interface
1839     0
Try to "shut/no shut" it from the network site first.
