NetMRI 7.0.5 - Rules & Policies with device filter does not correctly appl multiple group membership
1800     0
This is just a heads up from a recent TAC case I opened.
If you specify a device filter in rules or policies (always a good idea!),
and you include the device attribute of group membership,
and you list more than one group name, separated by commas with a trailing space,
the membership will not be correclty evaluated.
Easy workaround -- omit the spaces and use only a comma separator.
Another minor annoyance is that if you delete one entry from a sequence, the boolean expression is not updated to delete that entry.
E.G., boolean expression = 1 and 2 and 3
  delete #2
You must manually edit the expression to "1 and 3".
Both are expected to be fixed in some future version of NetMRI.
