NetMRI firmware downgrade and upgrade path from 6.4.x to 6.9.4
6816     0
Hi All,
I can't find the NetMRI firmware downgrade and upgrade path in KB and also release notes. Customer is now using version 6.4.x and we are proposing upgrade to 6.9.4. I tried manually upgrade from my lab but fail to do so, is there a guide or any document i can look through?
Thank you.
ILIEW
Re: NetMRI firmware downgrade and upgrade path from 6.4.x to 6.9.4
6817     0
Please open a support case, to get the links for the upgrade path
Long days of upgrade are ahead of you my friend Smiley Happy
Sif
https://sifbaksh.com
6817     0
For upgrade path you can refer to the following KB
#2847: Upgrading Network Automation from Version 4.3.1 to Version 6.8.8 or 7.0.2
As of now, you can't downgrade NetMRI. We do have an existing RFE to get that supported
6817     0
Hi Sif,
We have already open a case for this issue. We have got the upgrade path now.
the Upgrade path from 6.4.5 -> 6.9.4 should be as below.
6.4.5 > 6.5.4 > 6.6.0 > 6.6.3 > 6.7.1 > 6.7.3 > 6.9.4
ILIEW
