Network Automation using udp 40125
4380     0
i'm installing a network automation (6.7.3) on one of my customers.
i noticed in the firewall that there is traffic from network automation on udp 40125 to some of the devices.
i tried to find over the internet for what this port is using but i didn't find anything helpfull.
do you know what is the purpose of this port?
NMAP defaults to UDP 40125
4381     0
I think this explains it -- NetMRI uses NMAP for port scanning.  And NMAP defaults to UDP port 40125 for UDP-based host discovery.  See the doc at http://nmap.org/book/man-host-discovery.html.
Re: NMAP defaults to UDP 40125
4381     0
proper link: http://nmap.org/book/man-host-discovery.html
4381     0
Wow, this may be a new record for the oldest thread to come back to life -- over three years!  :-)
As you guessed, UDP port 40125 is used by nmap.  It is used during device discovery, as part of NetMRI's process for "guessing" SNMP credentials.  It is used specifically when NetMRI has been unable to guess working SNMP credentials, as part of a check for IP "reachability" that's a bit more reliable than a simple ICMP ping.
