Problem with the method: get_custom_field
SChacon
2632     0
I try to do a Perl script to check if a custom field for a device have a value. I try to use the method get_custom_field($field_name) but I don't understand how it's works. I put my script. Can you help me?
______________________________________________________________________________
use strict;
use warnings;
# script variables are provided as a global variable from the NetMRI job engine.
our $command;
our $output;
# NetMRI_Easy is a library that provides an easy interface to the NetMRI. You open a connection to the NetMRI by creating an instance of NetMRI_Easy. In this example, we call this instance $easy.
use NetMRI_Easy;
# Connect to the NetMRI
my $easy = new NetMRI_Easy;
# get the device id from the job engine.
my $device_id = $easy->device_id;
# retrieve the device
my $device = $easy->device;
my $commandStr;
my $StateJob;
$easy->log_message('info', $device->DeviceID . " " . $device->DeviceName);
$commandStr = "ping " . "10.1.1.100";
$StateJob = $device->get_custom_field(custom_state);
$easy->log_message('info', $device->get_custom_field(custom_state));
$output = $easy->send_command($commandStr);
if ($output =~ /Success rate is 100/) {
if($StateJob =~ /2/){
$StateJob = "0";
$easy->log_message("custom", "Etape1");
exit 1;
else{
$StateJob = "0";
$easy->log_message("custom", "Etape2");
elsif($output =~ /Success rate is 80/){
$StateJob = "0";
$easy->log_message("custom", "Etape3");
        exit 1;
else{
$StateJob = "0";
$easy->log_message("custom", "Etape4");
else {
if($StateJob =~ /0/){
$StateJob = "1";
$easy->log_message("custom", "Etape5");
elsif($StateJob =~ /1/){
$StateJob = "2";
$easy->log_message("custom", "Etape6");
        exit 1;
else{
$StateJob = "2";
$easy->log_message("custom", "Etape7");
  $easy->broker->device->update({
    DeviceID         => $device->DeviceID,
    custom_state      => $StateJob,
Re: Problem with the method:
2633     0
Can you please add the all.zip so we can see where it's failing?
Sif
2633     0
Didn't look though the entire script yet, here is something :
should be
$easy->log_message('info', , "Etape4");
SChacon
2633     0
Hello Sif,
I have try to change the log_message. The problem is to take the value in the Custom Field. My custom field is State.
I put the all.zip in my dropbox. You can take it.
https://www.dropbox.com/s/totdmt1m09nxc16/all.zip
Thanks for help me
2633     0
Add this after all your log statements
$easy->device->set_custom_field(custom_state      => $StateJob);
