Accepted Solution
Timeout waiting for device - During Juniper firmware download
3784     0
I am working on a script to upgrade my Juniper switches. Currently facing issues with *** ERROR: Timeout waiting for device ***.
The script is able to tell the switch to connect to my fileshare server over SCP and start the firmware image download. The juniper switch will download the file to a temporary folder in /var/home/su under a temporary directory named
...transferring.file.........XXXXXX.
The download takes around 2 minutes.
After the download is complete it will transfer it to my "final" destination, which is /var/tmp. This transfer takes couple of minutes and during this transfer, the script decides to time-out.
I have tried to modify script and trigger timeouts but no success. I end up with having a corrupt file in /var/tmp and the temporary file doesn't get deleted automatically either, have to manually delete it currently after every attempt.
Here is my script:
Script-Filter: true
Action: Get version
Action-Description : Get the running version
Action-commands:
show version
Output-Triggers:
SCP
Trigger: SCP
Trigger-Filter: true
Trigger-Timeout: 600
Trigger-Context: true
Trigger-Context-Enter: file copy scp://USER@X.X.X.X:/path/path/juniper/ex/2200-c/jinstall-ex-2200-12.3R10.2-domestic-signed.tgz /var/tmp
Trigger-Context-Password: PASSWORD\r
Trigger-Context-Exit:yes
Trigger-Commands:
SET: $DoNothing = ""
Action: test
Action-Commands:
show version
I have looked through the forums for guidance and even contacted Infoblox support, so far we've had couple of remote sessions but haven't been able to figure out the issue.
Anyone who has experienced the same before, or can chip in some tips?
Thanks in advance.
Anurag
Re: Timeout waiting for device - During Juniper firmware download
3785     0
Hello everyone,
We managed to solve this issue by setting up a HTTP server and downloading the file over http instead.
Thanks!
/Anurag
