Using memberof in Group Criteria
1249     0
Folks,
I'm hoping someone could shed some light on this. NetMRI doesn't kick back an error for the following criteria, but it also doesn't populate the group.
memberof ["Group1","Group2"]
and
not memberof ["Group3"]
Is my use of memberof correct?
Mark
Just tested it and that
1250     0
Just tested it and that should do the job.
