LACP and Infoblox
10018     0
Hopefully this will be an easy one
Does Infoblox support LACP and if so, does it support Active or Passive or both?
Re: LACP and Infoblox
10019     0
Hello ranmasao12,
Support for this protocol is internally known to Infoblox as RFE-58 & is yet to be implemented in our products. If you would like to be listed among the requesting customers, please get in touch with Infoblox support or your accounts team. Your accounts team should be able to set right expectations on this as required.
Best regards,
Mohammed Alman.
