Strange Syslog Messages
Not applicable
4406     0
Hi
I'm looking through my syslog and I get the following message keep appearing.
<code>
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(isc_app_ctxrun+0x32) [0x5abd10]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd() [0x5aee69]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(isc__taskmgr_dispatch+0x390) [0x5bee47]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd() [0x5bba14]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(omapi_iscsock_cb+0x9b) [0x4e105c]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(omapi_connection_reader+0x18) [0x4dcf72]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd() [0x4dcf38]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(omapi_signal+0xa5) [0x4e4016]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(omapi_io_signal_handler+0x2c) [0x4e0cdd]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(omapi_connection_signal_handler+0xb6) [0x4ddf53]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(dhcp_failover_link_signal+0xc6a) [0x45dac8]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(omapi_listener_signal_handler+0x2c) [0x4e02ad]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(dhcp_failover_listener_signal+0x79) [0x45c90b]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(dhcp_failover_state_signal+0x579) [0x45c50d]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(dhcp_failover_process_bind_update+0xbf9) [0x459802]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(supersede_lease+0x6d4) [0x465d80]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(uid_hash_add+0x8d) [0x4646e4]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: uid len 0:/usr/sbin/dhcpd(ib_check_fd_at_close+0x3a) [0x4dfea1]
Oct 25 11:26:39 10.96.0.17 dhcpd[2178]: Error at close: uid len 0 (backtace follows)
<code>
My log level is set at warning.  Does anybody know what this means or how I stop it?
Thanks
DHCP Failover
4407     0
OMAPI belongs to DHCP Failover. Maybe there is a misconfiguration?
