Alternative way to lookup for DNS unused records beside upgrading to SW ver. that support scavenging
3169     0
Any other alternative way to lookup for DNS unused records beside upgrading to SW ver. that support scavenging feature?
need to pull some numbers from the current version i use 7.2. before considering any upgrade to 7.3 that support the scavenging feature.
thanks
Re: Alternative way to lookup for DNS unused records beside upgrading to SW ver. that support scaven
3170     0
You could turn on the "last queried" feature and use that as a guide for manual cleanup.
3170     0
Ok i see and where is this feature located and how does it work?
Any precaution before using it to avoid unwanted impact?
Thanks
3170     0
Hello hasagh,
Please find below the procedure in NIOS 7.2 to enable Zone monitoring used for Last queried reports:
Regards
Nicolas
