Basic report on DHCP subnets
3049     0
I'm trying to find a way to report on the details of a set of subnets that are part of the DHCP services. I need to pull the basic information from each subnet, such as gateway, start and end address, and any fixed addresses within tthe subnet. I need to do this for a specific range of subnets and do not seem to be able to find a standard report that can do this.
Re: Basic report on DHCP subnets
3050     0
I'm not sure you'll be able to do this easily, you could try doing CSV exports and munging the data in Excel, or if you fancy playing around on the command line, see if "ibcli" can help - http://ibcli.blogspot.co.uk/
Else you'll be looking at the API.
Paul Roberts
PCN (UK) Ltd
